FM24C64汇编测试程序c语言(8052) -PLC技术网(www.plcjs.com)-可编程控制器技术门户
日期:2007-11-18 18:34:46     来源:   作者: 点击:
//THIS CODE WAS DESIGNED TO DEMONSTRATE HOW THE FM24C04/FM24C04A SERIAL FRAM COULD
//BE INTERFACED TO THE 8051 MICROCONTROLLER. THE INTERFACE USES 2 LINES
//FROM PORT 2 (P2.7 AND P2.6) TO COMMUNICATE.
//THE CODE SHOWN DEMONSTRATES A 'RANDOM READ' AND 'BYTE WRITE'. THE OTHER *
//MODES OF OPERATION CAN BE CREATED BY EXPANDING UPON THESE ROUTINES.
//深圳市华胄科技有限公司
//the first date writed:2003-11-20
#include
#include
#define uchar unsigned char
#define uint unsigned int
#define IIC_READ 0XA1    //定义读指令
#define IIC_WRITE 0XA0   //定义写指令
#define NOP _nop_()
//#define SDA INT0
//#define SCL T0
uchar idata buff[32]; //save the byte read out  form iic device in test operation
uchar idata readbuff[32];//测试数组,暂存写入读出数据
//uchar writebuff[32];
sbit SDA=P1^4;//P2^7; //THE SDA BIT IS PORT 2 BIT 7
sbit SCL=P1^7;//P2^6; //THE SCL BIT IS PORT 2 BIT 6
//sbit WP=P2^5;
//sbit test=P1^0;
//define a bit_operation byte to use in shift operation
//use this mode can achieve high operation speed
uchar bdata bbyte;//定义位操作用数组,采用此方法可提高位操作速度
sbit a0=bbyte^0;
sbit a1=bbyte^1;
sbit a2=bbyte^2;
sbit a3=bbyte^3;
sbit a4=bbyte^4;
sbit a5=bbyte^5;
sbit a6=bbyte^6;
sbit a7=bbyte^7;
bit IFACK; //record the SDA state to confirn if ACK has happened
bit NO_ACK; //no ack flag
bit BUS_FAULT; //bus fault flag
//FUNCTION:ROUTES TO PROVIDE A START SIGNAL
void start(void)
SCL=0;SDA=1;SCL=1;SDA=0;SCL=0;
//FUNCTION:ROUTES TO PROVIDE A STOP SIGNAL
void stop(void)
SCL=0;SDA=0;SCL=1;SDA=1;SCL=0;
//FUNCTION:ROUTES TO PROVIDE ACK SINGAL
void ack(void)
SCL=0;SDA=0;SCL=1;SCL=0;
//FUNCTION:ROUTES TO RELEASE THE SDA TO RECEIVE A ACK SIGNAL
//              OR TO PROVIDE A NO_ACK SIGNAL
//type=1等待应答信号
//type=0 产生无应答信号
void nack(uchar type)
SCL=0;SDA=1;SCL=1;IFACK=SDA; SCL=0;
if(type)
if(IFACK)//如果无应答信号,则置标志位NO_ACK,程序中止
NO_ACK=1;//用户可以加入自己的异常处理程序
//while(1);
else NO_ACK=0;
//FUNCTION:THE IIC DEVICE SHIFT OUT A BYTE  TO THE MASTER
uchar  inbyte(void) {//从IIC器件中读出数据
SDA=1;
SCL=1;a7=SDA;SCL=0;
SCL=1;a6=SDA;SCL=0;
SCL=1;a5=SDA;SCL=0;
SCL=1;a4=SDA;SCL=0;
SCL=1;a3=SDA;SCL=0;
SCL=1;a2=SDA;SCL=0;
SCL=1;a1=SDA;SCL=0;
SCL=1;a0=SDA;SCL=0;
return(bbyte);
//FUNCTION:THE IIC DEVICE SHIFT IN A BYTE FROM THE MASTER
void outbyte(uchar outdata) {//将数据写放IIC器件
bbyte=outdata;
SDA=a7;SCL=1;SCL=0;
SDA=a6;SCL=1;SCL=0;
SDA=a5;SCL=1;SCL=0;
SDA=a4;SCL=1;SCL=0;
SDA=a3;SCL=1;SCL=0;
SDA=a2;SCL=1;SCL=0;
SDA=a1;SCL=1;SCL=0;
SDA=a0;SCL=1;SCL=0;
//FUNCTION:BYTE WRITE.  'add'     THE WRITE ADDRESS, 'wbyte'   THE DATA WANT TO WRITE
上一篇: SC-501/DE系列PLC以太网远程设备监控系统
下一篇: 移动视频传输解决方案
